Hi Guys,
If you are like me you have most likely totally destroyed your rear sway bar mounting brackets more than once. This has a cascading effect on the bushing and thereby the travel of the rear differential. Most of the time you need to cut the old damaged bracket off to be able to replace them.
Well guess what Roy at Crazy Canucks 4x4 has just released a full custom set of rear Heavy duty sway bar mounts for the H2. I have been testing them for him on my H2 on the Polar Bear Proving Grounds! All I can say is that they are truly amazing! Gone is any worry about a rock crushing the bushing. Gone is the limited travel of the stock non greaseable set-up. Gone is the creaking from the sway bar trying to turn in the crushed bushing!
They are a true work of art...sad that I have to bash them into the rocks...but hey they seem to really like it!!
Here are a couple of pics of the ones installed on my H2. And yes I have cleaned and painted them for the purpose of these pictures...otherwise they did not stand out at all!!
Enjoy! And yes Roy Has some in Stock So Call Now!!! You can get them in time for Christmas!!!
Heavy duty Rear sway bar mounts for H2
- Autumn Walker
Re: Heavy duty Rear sway bar mounts for H2
Those look awesome - I actually removed my rear sway bar entirely last weekend. My stock brackets were completely destroyed.
2007 HUMMER H2
- thedub
you know if Kevin and Roy did these......... they will last forever <img src='http://www.canadianhummerclub.com/forum ... Rockon.gif' class='bbc_emoticon' alt=':rockon:' />
[center]Yellow H2
Mississauga, Ontario.
