Stock Tie Rods
Stock Tie Rods
Looking for a replacement for Stock Tie Rods and Pitman Arm, what have you used in the past that is stronger and more durable??
Re: Stock Tie Rods
I run MOOG parts all the way thru my front end, I did not upgrade to heavier duty tie-rods etc, since a tie-rod is relatively cheap and easy to replace on the trail. Consider your tie-rods fusible links, better to break them then something else way more expensive further up. Upgrade your parts above the tie-rods but leave the stock t-rods alone. I have never broken one yet and I off-road fairly hard, so the really should be an issue, at least the MOOG parts are lifetime guarantee! I always carry a spare for the trail rides just in case someone in the group blows a rods.<DIV> </DIV><DIV>Kevin</DIV>
Re: Stock Tie Rods
good to know....
Thanks Kevin
Derek
