Fuel Filter H2
- Gadgets
Fuel Filter H2
I was looking to replace the fuel filter, but I can't find it. Googling it pointed to where it may be, but if it is there I can't get there to see it. So my question is, how the hell do you replace a fuel filter on a 2007 H2??
<p class="bbc_center">
Re: Fuel Filter H2
Simple! There is no replaceable filter on an 2007!
- Gadgets
Re: Fuel Filter H2
[quote name='Polar Bear' timestamp='1355845806' post='41492']
Ooook then. Never heard of that before but some how doesn't surprise me. So how is the fuel filtered exactly?
Re: Fuel Filter H2
The fuel is filtered by a sock(thick long filter) at the base of the fuel pump located in the fuel tank. Normally when this is very dirty the fuel pump demise is close at hand. Sadly the only way to service this filter is by replacing the fuel pump assembly. Older H2s like my 2003 have an external fuel filter just in front of the tank behind and above the rear most frame crossmember.
Hope this helps!
Hope this helps!
- Gadgets
Re: Fuel Filter H2
Yup it helps, thanks. At least I can stop looking for it now. LOL
