hummer h2
spima
hummer h2
Post by spima »
good mornin to every one.
i have the hummer h2 model 2008 with 6.2cc engine and i have all the time problem with the transfer case chain.
did someone know why.
thanks.
Re: hummer h2
Can you explain more?
Is it breaking? Is it skipping?
Is this from highway use or serious off-roading?
Are you sure it is the chain?
Re: hummer h2
Oh no the infamous transfer case chain Rhino(08 H3 Alpha 5.3 l Q8 engine) destroied two along with gears and front diff. Chain stretched and destroied gears in diff and transfer case. Truck was in shop (Queensway ) for a month each time. Both times at Botland
citiboy
Re: hummer h2
Post by citiboy »
I never had any problem with my t-case since i got my truck....and yes, i do abuse it <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> .
<div> </div>
spima
Re: hummer h2
Post by spima »
good evening. yes my hummer have problem with the transfer case chain. i have replase 2 time and now again.
it skipping and not serious off-roading.
spima
Re: hummer h2
Post by spima »
i am not doing serious off-roading and not hart youse.
thanks for your answer everyone.
