So changed the battery in the H2 today get in it to go for the test drive no sound!!!
The radio is on functions just no sound!!
Was thinking fuse for the Bose amp any other ideas?? For tomorrow when I go to check things out??
Cheers
John
Changed the Battery in the H2 now I have no sound from radio!
- Beets
[center]REMEMBER:[/center]
- duncanpa
Re: Changed the Battery in the H2 now I have no sound from radio!
Hmmmm...maybe wife put it on mute to stop you from singing to the radio...!!!!!
- johnnyspikesH3
Try to disconnect the negative battery again . Then hook it up and try . If nothing still ? I would say fuse for sure .
- Gadgets
[quote name='JohnnySpikesH3' timestamp='1359168003' post='41951']
Yup, what Spikes says... can we say REBOOT. I had a strange problem with my radio after a battery disconnection in that the BOSE logo didn't come on when it started up but otherwise worked fine. After a couple days it corrected itself... was strange, so I'd with a reboot too.
<p class="bbc_center">
- Beets
was fixed by gremlins over night <img src='http://www.canadianhummerclub.com/forum ... /crazy.gif' class='bbc_emoticon' alt=':crazy:' /> Thanks for the info though
- Khamul
Welcome to gm....
