Picked up much needed dependable communications .
- johnnyspikesH3
I went for the fender mount antenna . I spent $140 all together Radio etc . Any H3 guys need part numbers and want to do the fender mount route . Hit me up i will send you part # . I posted a Pick of what it looks like on this red H3 . I believe this might be a 3 foot also . Not sure if it's a fire stick ? You get the Idea .
Last edited by johnnyspikesH3 on Mon Mar 18, 2013 10:06 pm, edited 1 time in total.
- Gadgets
Re: Picked up much needed dependable communications .
Got the radio installed yet? Make sure we see pics of the install once you are done... thems the rules you know! LOL
<p class="bbc_center">
- Sugarphreak
WERD! I want to see install pics!
- johnnyspikesH3
Still in the truck. Front driver side axle seal got a slow leak.Gota change that and front crossed drills.I have much to do .Then i also have to do the DayStar body lift i am grabbing off HUMMAN.Unfortuantley i am busy and cant find the time to get anything done on the rig right now .
Last edited by johnnyspikesH3 on Fri Mar 29, 2013 11:05 pm, edited 1 time in total.
