Looking for set of rear STOCK SPRINGS for an H2
can anyone help ?
Looking for REAR STOCK SPRINGS for H2
- BRUTE
- Beets
Re: Looking for REAR STOCK SPRINGS for H2
<a href="http://car-part.com/">http://car-part.com/</a>
Might help make sure you click distance will start from closest wrecker.
Cheers
JOhn
Cheers
JOhn
[center]REMEMBER:[/center]
Why not just jet a brand new pair from Suncore or Arnott Suspension?
The ones from Suncore are triple rate and the ones from Arnott are fixed rate.
I have the ones from Suncore and they are great!
At around $250 a set they are worth it!
- Khamul
I have half installed new lifted springs from Rancho...
Will finish tomorrow as long as not raining and can send a pick if you were looking for a lifted one...
- BRUTE
I will explain the situation.
I took out the stock ones over 3 years ago when I installed my lowering springs, I however did not take the stock ones and left them at the shop.
Fast forward to 3 years later and I'm looking at once again putting my stock springs back in because I want to gain the height back due to the substantial weight from the audio system. So I'm not really looking at lift springs, just want stock springs..hope that helps.
thanks again.... still looking by the way
- Khamul
Ooooooo......
Sorry, I'm an offroading enthusiast so I always go there...
Go to gmpartsdirect.com and view the catalogue, input your year model etc etc and then go to rear suspension... Work your way through and you will find them. $87 each.... Nothing wrong with that price and stock height...
Hope that helps!
Hope that helps!
- beeno
i just put new springs in my h2.
where you located.
msg me if your still looking
where you located.
