Torsion beam keeps getting loose.
- AllenAventador
hey guys so as the topic sugests i have been having this problem for a while, so i m really getting annoyed. what could be the problem. i m having the alignment done next week. any help i would rather upgrade the component at this point. thank you
- johnnyspikesH3
Re: Torsion beam keeps getting loose.
It say's you have a H-1
Your in the H3 H3-T SECTION . Well if it is a mistake and you own a H3 ? If your torsion key keeps loosening up for some reason . The Key could be damaged because there is a inner part on the Torsion key that can wear out if over cranked and improperly cranked .
How many times have you cranked the key , and was it on the ground or in the air ? I don't think you have broke the torsion bar itself cause it would be very noticeable . New keys are cheap , and you might as well level it while you are there .
Last edited by johnnyspikesH3 on Fri May 17, 2013 11:46 pm, edited 1 time in total.
- AllenAventador
Thank you so much and no its an H3 i dont know why it says an H1.
but really thank you!
- AllenAventador
to answer your question the car is low on one side (driver side) and fine everywhere else. but i will have that checked because its getting really annoying. i will do as you suggested. thank you
