rear speaker not working
masterpogi
Post by masterpogi »
After installing aftermarket stereo on my h2 i noticed the rear speakers not working, i checked the wires and connections and it is hooked up properly, i found some write ups that i need to bypass something to fix the problem....can somebody help me with my prob....
Thanks in advance
BioHazard
Re: rear speaker not working
Post by BioHazard »
This could be obvious, but sometimes the obvious things are overlooked. Your fading setting on your stereo isn't set to front only, is it?
Beets
Post by Beets »
With the h2 you need a bypass because of the bose system and something to do with onstar and the door chime the bypass are about 100 buck or you can bypass manually the amp wire harness is located under the center console
<a href="http://www.crutchfield.ca/SearchResults ... Adapter</a>
[center]REMEMBER:[/center]
