Not crazy - but OFF Road (in Ontario)
- yevych
Re: Not crazy - but OFF Road (in Ontario)
Looks like some nice trails!
- yevych
We do have nice trails
- just need to find the time to go ...
- PierreLucScott
Im having a hard time finding trails around Gta, do you know of good places. Nothing too extreme. I have H3 with 3 inch lift and 35``pro comps.
- yevych
[quote="PierreLucScott"]
If you don't mind driving for couple of hours to Bobcaygeon area (north of Peterborough) - there are number of different rating trails from easy to very technical... I do at least couple of trails in that area each summer... Will ping you if I decide to go in fall. If you register with of4wd: <a href="http://www.of4wd.com/">http://www.of4wd.com/</a> you can find good info about trails/rating/etc...
Do you have lockers? I think it is standard to have at least one in H3.
There are also few runs in Orillia area organized by John I believe - check under CHC Events.
- yevych
[quote="Polar Bear"]
Hey Kevin, I tried to pm you - but getting "The member Polar Bear cannot receive any new messages
Wanted to ask you about tie rods on your H2... did you install some custom ones?
No, stock ones with outer supports to strenghten the tie rod assembly . He did this mod on the trail up in Mont Tremblant trying to keep up to the H1 crowd. Busted 2 tie rods in 15 feet of hill.
Support bars made by Roys Shop.
- Toxicrider
Ardbeg has some nice trails as well.
- duncanpa
Ardbeg, that's my neck of the woods. Have often heard about the trails up there but never been able to go.....interested if anyone else wants to come up this way and try them out....
- yevych
[quote="Roy"]
Thanks Roy. Can you make pair for my H3?
