A little help please!
citiboy
Post by citiboy »
2009 H3 Base 3.7L, can somebody check the underhood fusebox for FUSE 32 RVC VSENSE+ 10A. I just want to know if the fuse is installed, mine is missing. I don't have any weird problems on the 3 or any codes from my Tech 2, just found out when i'm installing the windshield washer heater. Thanks!
Circuit/System Description
The generator battery control module (GBCM) monitors the battery voltage for precision electrical power management. The GBCM monitors both the RVC PWR B+ circuit and the RVC VSENSE B+ circuit to precisely determine system voltage. If the RVC VSENSE B+ circuit is 1.5 volts less than the RVC PWR B+ circuit for 7 seconds, then DTC B1390 will set.
<div> </div>
citiboy
Re: A little help please!
Post by citiboy »
OK, got my questions answered from another forum. Fuse had to be installed there. All is good.
<div> </div>
