TORSION KEYS
BRUTE
TORSION KEYS
Post by BRUTE »
Hello folks i figured i would ask here first before looking elsewhere.
Im looking for a set of GREEN KEYS or something similar which will provide me with an increase clearance of 2" up front.
Anyone ?
Khamul
Re: TORSION KEYS
Post by Khamul »
I used the T-Max keys on my Deuce and they worked perfectly...
BRUTE
Re: TORSION KEYS
Post by BRUTE »
I did some research and the info i got said the Green Key part number is
GM Part # 15592573
Is this correct ?
Just to confirm this will allow me to gain an additional 2" in lift up front. Is that correct ?
Re: TORSION KEYS
Correct
It took my rubbing a little (37s) to no more rubbing,
Also IF your stock keys are cranked, your ride will be smoother with the new set
BRUTE
Re: TORSION KEYS
Post by BRUTE »
Anyone have these for sale ?
Re: TORSION KEYS
 ebay--3+3 kit, may help out with the weight issue
<div>130697420630 for the pro</div>
<div>
<div>141394356431 for the DIY -- unloader tool comes with</div>
<div> </div>
<div> </div>
<div>Pm Big Dub, he had some availible in Sept 2013....</div>
</div>
BRUTE
Re: TORSION KEYS
Post by BRUTE »
Link Roy ?
Re: TORSION KEYS
copy number, go to ebay, paste number in and search  :coffeenose:
Re: TORSION KEYS
I would actually recommend you to upgrade your torsion bars to a higher spring rate instead of just the keys especially if you have added weight to the H2.
I changed mine from the OEM 6709lbs per bar to the next one up 7267lbs, I used my OEM keys and my ride is Perfect even with all the extra weight in my H2 and my Winches front and rear!
Here are the part numbers just in case you want to consider them!
15528957-LH (code GG) (Max torque 6709)
15528958-RH (code GG) (Max torque 6709)
15712411-LH (code WZ) (Max torque 7267)
15712412-RH (code WZ) (Max torque 7267)
15528963-LH (code GK) (Max torque 8615)
15528964-RH (code GK) (Max torque 8615)
15528965-LH (code GL) (Max torque 8782)
15528966-RH (code GL) (Max torque 8782)
15732338-LH (code XG) (Max torque 9054)
15732339-RH (code XG) (Max torque 9054)
BRUTE
Re: TORSION KEYS
Post by BRUTE »
Does changing the torsion bars lift the front end up automatically ?
