Alternator question
Alternator question
Ok, I have 1996 h1 N/A 6.5
So my alternator died, (I unplug battery and down to 7volts)
I go to my local parts store, and say 96 hummer 6.5 N/A and I get this alternator
Re: Alternator question
But when I remove my old one it looks like this
What's with the different ears?
I then tell another parts store 95 6.5 they give me a cross which has same bolts as first
Does turbos have those flater ears? My type is right across from each other,
My parts store said the 5.7 alternators "looked" the same so they will bring in to see Monday, but Shezzzz figured
Be easier then this,
Would anyone know if the gassers would fit? I worry about tach reading, if pulley is different ? I can use my old one ,
Check for an alternator for a 95 Chevy G-3500 van it should have the right alternator
try part #334-2429 APC or Autozone 21055  ... 95 hummer diesel.
I called Napa/ lordco / Canadian tire all said can't get, soooo that part number Roy mentioned
Is a gm reman part number for a deco,I called them and they can get but has to come in from usa, 7-10 days.
Am general says it's discontinued. Actually Napa said they can get a Wilson cross but a week to get,.
I drive daily so I took to a electric shop and within 2 hrs I had back in my hand!! Now sits at 14.2 v :)
Happy ending
The pic below was old one
That works also!! At least you are sure that it fits!!!
Glad it is all fixed!
Thank you all for always great advice and help, this was finished unit and installed :).
And yes....lol ... I was positive no fitting issues ,hehe
Glad to see it is fixed. Parts are geting tougher to find as these trucks were discontinued from 2004/6.
