First off does your normal operating temp change once you add Evans? In city with normal green coolant ,,I'm around 200 and normal hwy driving.
Scenario .... If I go up a little here I hit 220 by the top. Will/would there be any change with Evans? Or will it mostly protect if I overheat if something happened?
I seen the site but wow stuff is pricy, is there another reseller of that ?
I like the no pressure thing with Evans, I feel that one can avoid pressure leaks (lol, on hot summer days). I'm sure this summer I'm going to upgrade to a high flow pump and duel stats, and poundering Evans now if I show break down heheh
Evans waterless question
Re: Evans waterless question
Your temp can't run cooler than what your thermostat is set too.
However you will notice that your temperature will stay more stable and if it does creep up it will drop back down very quickly.
So far during our May rally, it was the first time my engine never went over 110 thanks also to my electric cooling fans but overall a major improvement!
Hope this helps,
Hope this helps,
