H1 proper wheel alignment specs
rex
Post by rex »
Hi H1 guys. I bringing my truck in local tire shop next week for rotation and wheel alignment.. Is there any specification i should tell the mechanic for them to do the alignment? Please advise. Thanks
Re: H1 proper wheel alignment specs
H1s have two very different alignment specs. One is for unloaded and the other for loaded.
In other words unloaded would be how your H1 would be most of the time.
Loaded means at or near max GVWR...that also means you would have several thousand pounds of stuff on board!
if you have oem ctis, make sure they use a 3/4 wrench to take off not a pry bar.
Ride heigt should be checked to make sure springs are good. Stock tires  --ground to sub frame 17-19 inches
front
 caster 2.5 to 3.5
 camber 0 to 0.5
 toe  0 to 0.19  toe in at front of tires
rear
camber 0.25 to 0.75
toe -0.19 to 0   toe out at front of tires
caster adjustment--cams, bolt torque  260 ft/lb
********pry brackets apart to adjust
wheel nuts 140 ft/lb
*****no pipe wrenches on tie rod sleeves -- bolts at 30 ft/lbs
