coil springs
- drm
coil springs
Does anyone in Ontario have any new or good used coil springs for H1 or HMMWV. I need front and rear. Thanks.
Re: coil springs
A couple years ago I got 2 used rear springs to replace my two broken one,...and I remember he had a few sets there back there
Was at Roy's shop "crazy Canuck "
Re: coil springs
Roy can hook you up! Btw, for the work involved put new springs, used springs just won't last!
And you should replace your shocks at the same time since you are taking everything apart anyways!
Re: coil springs
what weight do you require?.
front--- stock,winch,plow, uparmoured,
rear---- vari rate or straight
call me 519-801-0113
- hithere
Re: coil springs
Not sure it's late or not, but I have factory springs off my 99 that were removed at brand new. The truck came without a winch and was done in Rodhall springs and shocks before it was picked up. Let me know 3o674o8437
