Please help. Shifter stuck in neutral or drive.
NVRSTUK
Post by NVRSTUK »
Ok I don't know why this is happened. I got in my h2 today to go to Tim Hortons pulled in parking spot and go to put shifter in park. And it won't pass neutral. Tried numerous of times with. Depressing brake pedal. Shutting off and on in neutral. Nothing works. What could cause this to happen.??????
I'm not so worried for myself but if my wife drives the truck for an emergency while I'm working she's gonna get herself stuck somewhere she can't drive over.lol
Please if anyone has had an problem like this let me know. Can even call or txt me. 4162202528
Re: Please help. Shifter stuck in neutral or drive.
I THINK I had sorta this loooong time ago, and my shift thumb button didn't go down enough..
I took off the "top t part" to see the ' thingy' ( that's my tech talk, hehe) push up and down was a minor adjust, (you'll need an Allen or torks) for get off hand..,..
Not saying it's your issue but mine woulnt pass ""n" then was worked great after I adjusted
Now that m thinking of it, maybe my "T" handle was high on the shift stick , and once I loosened the screw I was able to lower the T and then worked...
NVRSTUK
Post by NVRSTUK »
I seen something like that on YouTube. I also can't put in 3 2 or 1 gear is there any issues with gear selectors on the trannys??? I'm out plowing today and can't get my hands on the truck till morning.
should be just a shifter issue.
