WTB: Eaton e-locker 19622-010
- citiboy
Hi, i'm looking for Eaton e-locker 19622-010 for 9.25 in. front diff. IFS for an 08 H2. Let me know. Thanks!
<div> </div>
<div> </div>
Re: WTB: Eaton e-locker 19622-010
New or Used???
- citiboy
i know this is discontinued but if i can buy it new then that would great, if not, then i have to settle with a used one.
Also, i find out that AAM 1866-694-4190 is identical minus the wiring harness and switch, which i don't need it as i'll be making my own harness.
I already e-mailed Phil at Trail Duty and he said, I have not been able to get these for a while now unfortunately.
<div> </div>
<div> </div>
There is always the ARB Air Locker, It is much stronger in overall design, and in retro spec I probably should've done those myself since I have gone thru 3 rear Eatons and 2 front Eatons.
You can run them from a small CO2 canister instead of a compressor.
Or You could add a spring kit to your current front diff which would make it more of a limited slip than a open diff and it would help the Traction Control System.
Oh you could also use the one from the Dodge Power Wagons!!! No harness just Locker, it is virtually the same
http://www.justdifferentials.com/ELAAM9-25-p/elaam9.25.htm
Carriers in GM & Dodge 9.25" fronts have the same deck height but Dodge housings run a "thick" gear. If installing this carrier into a Dodge housing with a Gm gear, you will need ring gear spacer MRG925A.
Darn, I wish I had found this when I did mine!!!
<div>
TracRite® GTL - Helical Gear with Electronic Locking Differential
<div>
AAM produces a wide variety of differential cases and assemblies for the aftermarket. Each is designed to the exacting specifications of the OEM vehicle manufacture. The TracRite® GTL combines the best benefits of both the helical gear design and the simplicity of the electronic locker. The GLT does not need friction additives or wear plates and provides for maximum torque applied to the wheel ends. Let your replacement differential assembly make your truck run like new or even better. Use the differential assemblies made by a leader in the axle manufacturing business.
Features:
</div>
<div>
<div>
Features:
- In unlocked mode functions same as the TracRite® GT helical gear limited slip differential
- Once activated has all the functionality of the TracRite® EL electronic locking differential
</div>
- citiboy
yeah, i.ve seen the AAM before. i might end up with it if i can't find the Eaton. i will be doing the 4.88 re-gearing soon, might as well install the front locker at the same time. I actually called JustDifferential this morning and spoke to Drew and he has it in stock.
<div> </div>
<div> </div>
