Well I started my truck (remote start) and seen a little blob of fluid passages side area ,......sooooooo I crawl under and see my hard as hell rubber y hose and noticed (after I break cleaned them) they were bad,..leaking from tranny /to Y-hose area
So lol, no job is simple, I size it up and figure 1/2 hrs max. Took like 3 hours
Well every clamp I undid ONLY the screw came off and the clamps seemed stuck to the rubber hose, I actually "on 3 clamp" has to dermel cut off the s/s band..
That has to be a pain area!! Lol cuts every ever from the other hose clamps,. I did the one side y set up and in few days will do the other but now , lol gonna make sure I get all new clamps/rubber tranny hose/ all on hand before I start...
Hose clamps
Hose clamps
Re: Hose clamps
Normal leak area from those hoses. Yes they get dried out and crack on this inner at the hose ends.
