Headlights won't work........... fixed!
Once in awhile my headlights would go out.
So I figured possibly a ground, then I would attach a power wire directly to the lights and it would work so that rules out the ground IMO, works then but for few days.
Sometimes I would flick the headlamp switch and half a second later the lights would turn on ,never knew what that was just chalked it up to the trucks personality hahaha
Then I read that the signal switch often goes faulty so I go and change that again it starts to work right away only for a few days.
Again after the lights stopped working I took my headlight switch out and then hook the power wire up to it and all the Outlets of the switch worked so knew that was good.
Then spend a good couple weeks going insane in my head figuring it out I figured maybe the maxi fuse circuit breaker was part-time faulty so I replace that.
Shockingly again it starts working for a few days after I get this false sense of security it stops working again.
Then I remembered Roy and I had my hood off when we did my repairs so I checked the connectors again but they were all perfectly good.
Lol then recheck grounds and even ran a new one. Still dead.
I was about to take my headlight switch and throw it across the road and then noticed the female plug it goes into was burnt up pretty good.
But back internal. I swear it was the weirdest spot ever it cannot just be something nice and simple.
The few days is up and it is still working after I cleaned all the terminal Spades and grinded things smooth as it had a black film from the power.
Just wanted to put this out there in case anyone ever runs into this headache I had to find
