DRL on Imported Vehicles
duncanpa
Post by duncanpa »
Guys,
There is a new memo out on Hummer H2's about the DRL's.  The ability to shut off the DRL's is no longer accepted in Canada.  This feature has to be defeated.  They will try to sell you on buying a new module for around $500.00, but all you really need is a wiring diagram and cut the wire from the switch to the ground for the off feature of the DRL's.  This makes the DRL's full time on automatic and they cannot be shut off.  Problem solved...solution cost...nothing!!
Patrick
