Just a quick update to the Winter Tire Law. The Government has included the following conditions since there are some difficulties with tire supply so here are the conditions.
Any words on the sidewall that say Arctic, Blizzard, Winter, Ice, Stud, etc. in other words anything to do with winter...duh!
Also they stated very Clearly that tires that Have Mud and Snow DO NOT QUALIFY AND ARE NOT ACCEPTABLE!!! BUT, and you'll love this, any tire that has LT designation IS ACCEPTABLE! So if you have mud tires they are no good but if you have slicks that are LT whatever then Bobs your Uncle! How DUMB is That!!! <img src='
http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt='::)' /> <img src='
Also they have now made another category. Weight Rating. So if the vehicle is over 4500kg GVWR You are EXEMPT....but only if used for commercial or fleet if private then, you must comply with the law!
If you are between 3000kg and 4500kg you are exempt if it is used for Commercial but not for private, in other words you must have an F-plate or an L-plate no private plates!
And if that isn't enough they said that regardless of the above any infraction will be judge on a Case by Case basis.
Sounds like Nobody Knows Anything!!! <img src='
Guess we'll just have to keep pulling cars, trucks and emergency vehicles out of snowbanks before they Get A Clue! <img src='
http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> <img src='
