Max Tire Size?
Ironjax
Max Tire Size?
Post by Ironjax »
Hey Everyone.....New to the site and to the world of H2.  I have to say I thought my truck was awesome but this site is wild!!  I'm wondering what is the maximum tire size a person can put on a stock H2 SUT?  Again, no lift kit just right off the show room floor.  Thanks in advance for your replies and have a safe & awesome Christmas everyone!!
Re: Max Tire Size?
You can fit 37s no problem. All you need to do is crank the torsion bars a couple of turns and your done!
hummerht
Re: Max Tire Size?
Post by hummerht »
Post pictures of the SUT SVP.
Stef
Ironjax
Re: Max Tire Size?
Post by Ironjax »
Thanks WhiteHumH2 and Steph I will post pictures ASAP.  Thanks again and later guys!
Re: Max Tire Size?
37s fit with thye bars ctranked, width is 12.5 but if you put on the 13.5 you will have to a bit of custom cutting.
Lex
Re: Max Tire Size?
Post by Lex »
Hello friends!
Excuse me for my English first of all- I'm not native English speaker: Russian, from Moscow.
I'm reading your forum from time to time. Now I've got a question and hope to get a help.
I have an idea to put on my H2 22" wheels with tires Pirelli Scorpion ATR 325/55 R22
The only thing I'm warried about is - would those wheels/tires touch anything with a maximum turn?
I mean- when I turn a driving wheel to the limit left or right - could I get a risk of tires getting into contact with a body or any arms?
I would appreciate any advise you can give me.
Thanks!
Re: Max Tire Size?
[quote author=Lex link=topic=799.msg6711#msg6711 date=1237845042]
Hello friends!
Thanks!
Lex, KEVIN is the man ...i am sure he will help you out [img width=60 height=60]http://i304.photobucket.com/albums/nn18 ... 6_1_37.gif[/img]
[img width=500 height=409]http://i304.photobucket.com/albums/nn186/TONY2105/th_Picture086.jpg[/img]
Lex
Re: Max Tire Size?
Post by Lex »
Thanks, TC!
I've sent him a private message.
Hope he can advise on this!
Re: Max Tire Size?
BY THE WAY THE WHITE H2 IS KEVIN'S .....TAKE LOOK AT THE TIRE HE HAS ...THERE BIGGER THE MY MT/R'S ON MY H1....TOYO IS BRAND......
Re: Max Tire Size?
Hi Lex,
Well first off there is nothing definite with what I am going to tell you, it all depends!
You list a 325/55R22 so first we need it's dimensions so we do the following:
325 x 0.55 =178.75
178.75 x 2 = 357.5
357.5/25.4 = 14.07
14.07 + 22 = 36.07in total diameter
325/25.4= 12.79in width
so you have a 36x13.00R22 tire
Depending of the backspacing of the 22s the should fit perfectly if the backspacing is close to factory. If they stick way out of the fenders then they are goin to rub!
Since I run 37x14.50R17 I would highly recommend a torsion bar lift to help reduce any possibility of rubbing. Besides I have gotten used to the tire rub on my front sway bar during turning off-road at full suspension compression.
Hope this helps!
