H1 & H2 Comparison
- spies
Re: H1 & H2 Comparison
How tall of a tire does a H2 need to have 18" ground clearance?
[quote name='spies' date='18 March 2010 - 05:37 PM' timestamp='1268948279' post='14806']
Body clearance or differential ground clearance?? <img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' />
- spies
Diff. clearance, body clearnce doesn't have much to do with tire size.
[quote name='spies' date='19 March 2010 - 04:51 AM' timestamp='1268970670' post='14818']
Actually it does!
My H2 sits on 37s and I have 24" of clearance to the body. I have 14" of clearance under the front diff and 11" under the rear diff.
You would probably need 44s to get 18" of clearance under the rear diff!!
Actually it does!
[quote name='Polar Bear' date='19 March 2010 - 06:33 AM' timestamp='1268998412' post='14819']
Actually it does!
thanks for the info <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Actually it does!
- spies
[quote name='Polar Bear' date='19 March 2010 - 12:33 PM' timestamp='1268998412' post='14819']
Actually it does!
Actually it does!
- spies
There really is no "probabaly" in that answer. It's simple math. If we assume your 37" tires are true measure and you only have 11" diff. clearance, that would mean your diff. cost you 7.5". 37/2 = 18.5 - 7.5 = 11 . So to get 18" diff. clearance you would need (7.5 + 18) X 2 = 51 , 51" tall tires. My point was that an H1 can achieve 18" diff. clearance on 39.5" tires. Just another comparison.
[quote name='spies' date='19 March 2010 - 10:42 AM' timestamp='1269013326' post='14826']
BRAVO <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
[quote name='spies' date='19 March 2010 - 11:42 AM' timestamp='1269013326' post='14826']
this is great......MATH LESSONS...... <img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' /> <img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' /> <img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' />
