If you are asking yourself why would you need something like this...go and price out what the AMG replacement assemblies cost and then when you wake back up from passing out you will understand. As of today they are approximately $500 LH and $900 RH each.
A Hummer Parts Guy Exclusive solution to a common issue for worn out window motors. This kit includes everything you need to repair your existing window motor assembly. The repair only takes approximately 45 minutes and uses your existing wire harness (plug and play) and metal cable guide.
I will also rebuild your existing assembly and perform the upgrade if you send the old assembly to me. FREE
Kit Includes:
* Detailed instructions with photos
* New window motor and gear
* New motor cable
* New mounting brackets
* Misc Hardware
Introductory price of $150ea + shipping (USPS).
Part Numbers:
6002871KIT > REGULATOR KIT, WINDOW, POWER (RH)
http://www.hummerpartsguy.com/product.asp?itemid=14676
6002870KIT > REGULATOR KIT, WINDOW, POWER (LH)
http://www.hummerpartsguy.com/product.asp?itemid=14675
Thank you. Please let me know if you have any questions.
David Oberer
1996 AM General 6.5L NA
Hummer Parts Guy - Canadian Hummer Club Sponsor
Blackberry: 920-216-6898
Website: www.HummerPartsGuy.com
