Finally Got My Scangauge Mounted
98hmc4
Post by 98hmc4 »
I finally had time to cut a mounting block out of wood and paint it black. I then used silicone to hold it to the dash. Then I used Velcro tape to hold the scangauge on. I attached a few pics, sorry there not the best pics, I used my cell to take them.
Re: Finally Got My Scangauge Mounted
Where did you get the Scangauge from?? How do you like it??
Just read their web site... I'm screwed..
1996 WORKS ON ALL EXCEPT: Ford, GM and Dodge trucks with diesel engines.
98hmc4
Post by 98hmc4 »
[quote name='dwaxman1' timestamp='1302316934' post='26766']
I bought it used from someone from the TDI Club forum. I like it alot. Anyhing it displays is more accurate then the factory gauges. I can also see tranny temp and some other things. It also displays fuel mileage and kms to tank empty.
Too bad it won't work on your truck. I think ODB11 came out in 1998 and that is what this works on. <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' />
need to try one
