Engine Oil H1
Engine Oil H1
Which Oil do you use and why? know some guys havew a perference, others go with price...let me us know your thoughts as well as do you use any oil additive, lucas or something??
- tylerlisk
Re: Engine Oil H1
Rotella oil, and Lucas for everything else. Great quality and the price is right!
- paulg
Re: Engine Oil H1
rotella t 15w40 in the motor
red line hightemp synth atf in trans an tcase
redline synthec 75-90 in the diffs
lucas hub oil in hubs
lucas grease in everything that needs it.
probably going to flush the powersteering and use redline synthetic there as well
i am also installing a dual remote bypass filter for the engine, its the amsoil bk23 kit i think with ea26 and eb100 filters
[left]2001 black HMCS
3" bodylift
Heath Programed ECU
Remote PMD
CMGS water\meth injection
Rear head cooling kit
Scangage II
Boost, EGT, Temp gauges.
Dynamat extreme
dual optima red tops
Straight piped exhaust[/left]
3" bodylift
Heath Programed ECU
Remote PMD
Scangage II
Dynamat extreme
- Hesh
Re: Engine Oil H1
Rotella T6 Synthetic
Lucas Hub Oil
Eneos Syntetic Diff Fluid
Lucas Hub Oil
- 98hmc4
Re: Engine Oil H1
Amsoil in everything with dual bypass filters for the engine.
- paulg
Re: Engine Oil H1
not tryin to thread hijack,
98HMC4 where did you install you bypass filter mount? i am getting ready to install mine now and would like to see how others have tackled it, maybe a new thread and a couple pics. THANKS!
Hijackin done...
Hijackin done...
3" bodylift
Heath Programed ECU
Remote PMD
Scangage II
Dynamat extreme
3" bodylift
Heath Programed ECU
Remote PMD
Scangage II
Dynamat extreme
- Sub
Re: Engine Oil H1
[quote name='dwaxman1' timestamp='1302350830' post='26782']
AMZOil 15W40... CANADIAN TIRE
Re: Engine Oil H1
But now that you mention it... Need a photo of where that dual oil filter is installed..
Have you found a difference with Synthetic oil?? I use it in my H2 and in my cars but not in the H1 for engine Oil...
- Sub
Re: Engine Oil H1
I JUST BOUGHT DUAL OIL FILTER KIT AND WILL BE INSTALLING IT NEXT OIL CHANGE, ANY ISSUES WITH INSTALLATIONS YOU GUYS HAD SO I NEED TO BE AWARE OF? I THINK ITS SHOULNDT BE THAT HARD TO HAVE IT INSTALLED, YOUR THOUGHTS?
ALSO ANYONE IS AWARE OF "PUROLATOR" OIL FILTER? GOOD / BAD / AVERAGE? I GOT EM WITH THE KIT , WONDERING IF THEY ARE ANY GOOD...
I USED MOBIL 1 SYNTHETIC EVERY WERE ELSE - DIFFS/TRANSFER/TRANNY -ANYONE USES SAME OIL?
- Sub
Re: Engine Oil H1
[quote name='dwaxman1' timestamp='1302401590' post='26814']
I dont beleive in mineral oil as the best option for the vehicle....i just cant settle on the fact that i am cheap on this cheapest thing i can do to save myself from potential wear damage.I aways like to say : I just simply cant afford to put cheap oil -not worth it
