Nord-Lock washer and New Half shaft Bolts
Looking for a set of new bolts and Nord-lock washers for my truck.. anyone know of a good place to get them??
Roy, you have any in stock??
Darcy
Re: Nord-Lock washer and New Half shaft Bolts
Post by Darcy »
fastenal dude any nut and bolt place should sell them
Tom
Post by Tom »
Roy has a bunch in stock, he's got the right bolt with a nice lip on it that will hold the nord lock really well.
paulg
Post by paulg »
blue hummer outfitters sells a replacement set that use locking tabs and are reusable.
http://www.bluehummer.com/lohabokit.html
[left]2001 black HMCS
3" bodylift
Heath Programed ECU
Remote PMD
CMGS water\meth injection
Rear head cooling kit
Scangage II
Boost, EGT, Temp gauges.
Dynamat extreme
dual optima red tops
Straight piped exhaust[/left]
[quote name='dwaxman1' timestamp='1306435056' post='27872']
Yes keep in stock, about 200 pcs of each!! <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Thanks Roy, Got them from Markus last night!
