OH OH
AmpGramp
OH OH
Post by AmpGramp »
Got a hole in my rad and the vehicle over heated. Not for long as I pulled over right away.
Had a new rad put in and now I find it over heats easily. Alos the oil pressure is lower on the gauge than it use to be. but still with in limits.
The vehicle has 70.000 miles on the odometer. Mostly highway miles. I woul like to put the cat engine in.
I can have it done in Vancouver, Edmonton, Calgary or Winnipeg. Any suggestions as who to use ?
Regards
Bob Fitz
Re: OH OH
[quote name='AmpGramp' timestamp='1306858448' post='27991']
Regards
Bob Fitz
12 or 24 valve cat??
I know of a company whom is in the works of making a plug and play replacement kit for these motors.May take a few months for the first two to get done, but the finished product will be worth it! Will keep you informed as I get more info. <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Hesh
Re: OH OH
Post by Hesh »
Putting some more info on what year truck you have, and motor type might help.
AmpGramp
Re: OH OH
Post by AmpGramp »
[quote name='Hesh' timestamp='1306862207' post='27994']
Hesh
Sorry about that, the wagon is a 2004 with a GM deisel.
Thanks
Bob Fitz
tylerlisk
Re: OH OH
Post by tylerlisk »
Have you checked to make sure there are no air bubbles in the new rad?? this will make it overheat quick! I have a friend who owns a rad shop if your not sure.
AmpGramp
Re: OH OH
Post by AmpGramp »
[quote name='geckosupastar' timestamp='1306877024' post='28001']
Bingo gecosuperstar
Exactly what it was. I bled two of the three ports and the problem is gone. But I am still interested in an engine swap Cat or Cummings.
I plan to leave the Hummer at the lodge for guest who want to explore some of the old logging roads (supervised of course).
Regards
Bob Fitz
tylerlisk
Re: OH OH
Post by tylerlisk »
[quote name='AmpGramp' timestamp='1306898332' post='28008']
Bingo gecosuperstar
Regards
Bob Fitz
Wow, I was actually right! I should show this post to my wife!! see, a man is right from time to time!! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Ha Ha, anyways, I have worked on a few coolant systems in my life. Glad I could help you out!
Tyler
Darcy
Re: OH OH
Post by Darcy »
i think a cummins be the way to go ive been researching the whole cat 3208 set up was thinking of doing it put the pain is mounting a tranny to it
i mounted a 6bt cummins to my 4l80e relatively cheap about 1800$ for the adapter and trans controler
Re: OH OH
[quote name='geckosupastar' timestamp='1306898574' post='28009']
Tyler
Nicely done Tyler!
AmpGramp
Re: OH OH
Post by AmpGramp »
[quote name='Heavyde' timestamp='1306973897' post='28015']
Are you saying my existing transmission is useable if I purchase a kit. If so Cummins is the way I would go or the drop in unit that will be ready in a few months.(Thanks Roy)
I have two cummins in my boat and they are great. Pushes 42' @ 16 knots.
Regards
Bob Fitz
