Removing seats in an H1
- lamkai
I just got some new leather seat covers for my H1 but I can't put them on in the rear unless I can take the seats out. That is because the seat goes right to the back and the ceiling is too low to take the head rest off too. Does anyone know how to remove them or how I can get instructions on removing the seats?
- 3dinnovations
Re: Removing seats in an H1
[quote name='lamkai' timestamp='1317246374' post='30753']
DRIVER’S AND FRONT PASSENGER’S SEATS
Standard Driver’s and Passenger’s Seat
Pedestal Repair
NOTE: Seat pedestal repair is similar for driver’s and front
passenger’s seats. This procedure covers the driver’s seat pedestal.
Removal
1. Remove driver’s seat pedestal.
2. Remove bag from height adjuster (Figure 10-31).
3. Remove nuts, lock washers, and bolts securing height
adjuster to slide set and remove height adjuster and cover.
4. Remove nuts, lock washers, and bolts securing riser to
slide set and remove riser.
Installation
1. Secure riser to slide set with bolts, lock washers, and nuts
(Figure 10-31). Tighten nuts to 24 lb-ft (33 N•m).
2. Secure cover and height adjuster to slide set with bolts,
lock washers, and nuts.
3. Install bag on height adjuster.
4. Install driver’s seat pedestal.
_____________________________________________________________________ Body 10-23
5745279
Reclining Driver’s and Front Passenger’s
Seat Replacement
NOTE: Reclining driver’s and front passenger’s seats are replaced
similarly. This procedure covers the passenger’s seat.
Removal
Remove bolts, washers, and passenger’s seat from seat base
(Figure 10-32).
Installation
Secure passenger’s seat to seat base with washers and bolts.
Tighten bolts to 15 lb-ft (20 N•m) (Figure 10-32).
Figure 10-32: Reclining Front Seat Replacement
Driver’s and Front Passenger’s Seat Pedestal
Assembly Replacement
NOTE: Seat pedestal assembly replacement for driver’s and
front passenger’s seats is similar. This procedure covers the
Removal
1. Remove seat from seat pedestal.
2. Remove four bolts, lock washers, and washers securing
seat pedestal to floor.
3. Remove seat pedestal and four spacers from vehicle.
Installation
1. Install four spacers and seat pedestal in vehicle.
2. Secure seat pedestal to floor with four washers, lock
washers, and bolts. Tighten bolts to 24 lb-ft (33 N•m).
3. Secure seat to seat pedestal.
Driver’s Seat Armrest Replacement
Removal
1. Remove plastic caps covering exposed screws.
2. Remove short screws and lock washers attaching armrest
to bracket (Figure 10-33).
3. If bracket needs to be replaced, remove long screws
attaching bracket to seat support.
Figure 10-33: Driver’s Seat Armrest Mounting
Installation
NOTE: If bracket was removed, perform steps 1 through 3.
1. Secure bracket to seat support with one of the long screws.
Do not tighten screw (Figure 10-33).
2. Use large center hole in bracket to locate upper bracket
mounting hole in seat support.
3. Secure top section of bracket to seat support with the other
long screw. Tighten both long screws to 120 lb-in. (14
N•m).
4. Secure the armrest to the bracket with the short screws and
lock washers. Tighten the short screws to 120 lb-in. (14
N•m).
5. Position the plastic caps over the exposed screw heads.
NOTE: The entire armrest can be positioned vertically or horizontally
by pushing the armrest up or down. To adjust the angle
of the armrest while it is in the horizontal position, use the
adjusting knob located under the front end of the armrest.
6. Use the adjusting knob to position the armrest as
necessary.
Pedestal Repair
Removal
Installation
5745279
Seat Replacement
Removal
(Figure 10-32).
Installation
Removal
Installation
Removal
Installation
N•m).
N•m).
necessary.
Ride Hard!
now that is the most detailed instructions I have ever seen :-)
Excellent job!
Excellent job!
- 3dinnovations
Here's the same pages with PDF included for the pictures. I couldn't do it on my Mac last night.
Hope it helps.
Hope it helps.
Ride Hard!
- lamkai
[quote name='3Dinnovations' timestamp='1317300212' post='30777']
Hope it helps.
That is awesome, thank you so much!
Hope it helps.
