Help with wiring
logicbyondreason
Help with wiring
Post by logicbyondreason »
Hello to everyone! My name is Pavel and I own a 1995 H1 Wagon with a 6.5 NA. When I got it the speedometer did not work and I have read about them failing around the 90k mark which I am at now. I read on Flashoffroad about replacing it with a VDO and went ahead and bought one. When i was installing it i noticed that there has been a modification with the harness. The yellow wire which I believe is the signal to the speedo has been bypassed with a black wire. I traced that black wire and it goes directly to the vehicles speed sensor. I had the idea that the signal is sent to the digital ratio adapter and then to the gage. I want to make this right and am looking for some knowledge. If i hook up the speedo with the black wire i can get it to read the speed but the needle does not stay steady. It tends to show plus or minus 2mph. If anyone has a wiring diagram showing how the speedometer is wired to the speed sensor please share. Any other information would be greatly appreciated. Thank you.
humtek
Re: Help with wiring
Post by humtek »
What is a VDO and what is it four.
3dinnovations
Post by 3dinnovations »
[quote name='logicbyondreason' timestamp='1317586064' post='30907']
Here you go. Hope it helps!
Ride Hard!
Darcy
Post by Darcy »
ARE YOU TALKING ABOUT THE DRAC BOX
I RAN INTO THIS ISSUE RUNNING BIGGER TIRES
DAKOTA DIGITAL ALSO MAKES AM EASY MODULE THAT HOOKS DIRECT TO TRANNY SPEED SENSOR THAN TO SPEEDO THAT IS ADJUSTABLE
GreenMeanie
Post by GreenMeanie »
I would have though the ECM would have filtered the signal but then i realize its a 95. After seeing the diagram it looks like the dra is the middleman. Learn something new everyday.
Pins 7 and 12 on the dra are input from the sensor that tames the resolution and output the hi res signal on pin 10 to the cluster.
