12k ECV axles 2002 H1
- DerekCanuck
Good day, I purchased some ECV 12k axles, the part number I will update the post shortly. I have some advice from HPG that I need to run the solid rotors for this upgrade. Does anyone know what the OD of the solid rotors are? 10.5" or 12"? Also can someone advise if the ECV Humvees run the 12" solid rotors? Just trying to put two and two together. Looked on flash off-road but no luck anyone know if there is a cross over part number for 2006 h1 tone rings? For instance are they produced by ford or GM for another of their vehicles? aMerican General doesn't seem to have any in stock.
Re: 12k ECV axles 2002 H1
Are they all the same lenght? if so, diff centring is required and 12 rotors are acceptable. Other than that, I have no input
- DerekCanuck
Hello Roy, yes all same length rears,part number 12460369-4, haven't decided on the diff centering kit as of yet, may look to pick up a proper left and right front shafts 12k versions.
In terms of the rotors has anyone had any experience with the solid rotors that were run on some of the heavy Hmmwv models?
Why the heck would you want solid rotors?
Do you mean to Say Slotted Rotors?
That would make more sense.
OEM rotors are vented and they have to be otherwise they will warp.
The Up-Armoured Military H1s ran 12inch vented rotors with full metallic pads that would squeal like crazy!
- DerekCanuck
I have seen the vented rotors and the solids, I would prefer vented for sure, just had a recommendation by HPG that solids were required with those axles. I could really use a manual that shows parts compatibility
