Has anybody replaced the Cognito upper control arm ball joints? I replaced mine twice in one year, wtf???
This time, i will be replacing it with Moog Problem Solver K6292.
Cognito upper ball joint
- citiboy
<div> </div>
<div> </div>
Re: Cognito upper ball joint
I replaced both the upper ones last year during the ARB Rally. That was the first time I had replaced mine since I had installed my Cognito Upper Arms 5 years ago.
I installed the MOOG upper ball joints from a K3500...I will have to check the part number.
I carry two spares now. I really beat mine hard during the rally and I stretched both of them!!
- citiboy
Ordered 2 from amazon.ca for $32 each free shipping, beats the Cognito warranty return shipping.
Can't find the Moog Severe Duty SD692DM here in Canada anywhere.
<div> </div>
<div> </div>
Look up these Moog parts---retail approx price
Upper
K100108 Problem Solver; adjustable; adjustment range -3 to 3 deg. of camber or caster $180
K6696 Problem Solver - ball joint orientation noted, where applicable $150
Lower
K6693 Problem Solver - Incls oversized stud ball Dia for superior load-carrying capability $130
Yes, they are pricier than Amazon, was just seeing if these are the heavier joints
Upper
Lower
- citiboy
Thanks Roy, for the life of me, i can't find Moog SD692DM anywhere even on Moog website except this store. Could it be just a K6292 rename part number especially for them?
<div> </div>
<div> </div>
Twice in a year? Shezz, hopefully next set is the charm
I have the K6292 ones installed at 2 spare!
