I used this http://www.amazon.com/gp/product/B0060NKA1U?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
Also, did this:
replaced transmission filter, transmission pan and gasket (old pan we're dented from off-roading)
completely flushed the transmission fluids with oem dexron 6 and reset transmission fluid life to 100% with Tech 2
replaced transfer case fluids with oem dexron 6
replaced front and rear differential fluids with oem 75w90 synthetic gear oil
replaced rear brake pads and parking brake shoes
replaced torsion bar cross member bushings
Serviced front brakes
Need right rear parking brake cable, siezed, parts on order.
Road test result with the new external cooler (about 20 km distance), will update for long term use:
54*C at idle with 90*C engine temp.
65*C at 110 km/hr with 28*C outside temp
I used to run around 98*C with the stock tranny cooler.
I will see if i need to install the by-pass valve in the winter.
