Now just to clarify when I say suspension lift, I don't mean just a torsion bar crank. I mean something really dramatic.
Kev was saying the Rancho 4" Lift is no good, loss of ground clearance in addition to custom fender flares are needed. I was thinking about it more and that makes sense; when you look at the amount of hardware you have to bolt onto the underside and then consider that you are not lifting the tires, rather than the frame all that extra hardware just makes your truck that much closer to the ground.
So the question remains, can you lift the H3 any other way? The only other things I have heard about are the Samco rear shackles and the 1" body lifts.
I think for certain I will be doing a body lift just to give me literally a little more breathing room in deep water.
Is there anything out there for a 4" front lift?
