Bumper search
Hunner
Bumper search
Post by Hunner »
I saved this shot from sometime back, I think from one of your runs up there. Can someone help me contact this owner to get some info on that bumper? I have that winch but need to change my front end to get rid of that plastic junk!
08H3ALPHAHunner Edition!WarnPowerPlant9500,Warn9000ti rear,Steelcraft brush/winch mt,RockyRoadrails/Hunner mod,GMUCP,Hunner shock skids,OEM roof lights,Rola roof rack,2GoLight spots,Hunner steering rackmounts,Cranium diff guard,Bulletproof custom tierods,front longer adjust swaybar links,Hunter intake,Jamboree rack,Bilsteins fronts&rear,extended jounce,snorkle,Sy-Klone pre filter,Hutchinson beadlocks & Cooper STT 35's for offroad GOT HUNNER EXtreme skids?
Sugarphreak
Re: Bumper search
Post by Sugarphreak »
Have you checked out the ARB bumper? TC can hook you up! <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
If I was to do it all over again I would have gone this route... that or the Defelice.
Hunner
Re: Bumper search
Post by Hunner »
[quote name='Sugarphreak' timestamp='1288884371' post='22523']
Are you the guy I sent some skids to at a resort in the US for a wheeling trip?
I really like my winch out in the open. I have winched for many years (since the 60's) and have seen the snarffle concealed winches can have or submerged problems in mud. We got gumbo mud down here. I like the ARB I just want a little different mount for the winch. I also like my power plant winch which needs to be exposed.
I may have to come up with something like just the winglets on the outer edges and a flat verticle piece across the middle. Then use incorporate what I have. Maybe someday? I think that might be the Tough Country bumper.
Sugarphreak
Re: Bumper search
[quote name='Hunner' timestamp='1288886436' post='22524']
Are you the guy I sent some skids to at a resort in the US for a wheeling trip?[/quote]
<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt=':huh:' />
Nope, I think you have the wrong guy!
Re: Bumper search
Hey our ARB bumper works fine with a T-Max winch our problem was the T-Max control box corroded due to bad paint. winch stays clean due to ports on sides.winch sides can be reached thru two large oval holes behind our hella lamps in fact the only holes drilled were for the winch control. Also the bumper has a flat surface allowing the setting down of controller ,shakles pins or other equipement during towing set ups.
The small marker signal lamps are included the fogs are optional
bunger
Re: Bumper search
Post by bunger »
[quote name='Hunner' timestamp='1288883835' post='22522']
Can someone help me contact this owner to get some info on that bumper? I have that winch but need to change my front end to get rid of that plastic junk![/quote]
Hunner, that H3 belongs to Yanni (YAT74 on CHO). That's a Tough Country bumper.
Re: Bumper search
Great looking H3, need some shots from different angles...
Copperhead
Re: Bumper search
Post by Copperhead »
HI guys, I sure like that ARB bumper on red hummer pic, I take it from some of the posts you are pretty happy with. I like the way the winch is kinda hidden. Quick question, is it a pretty easy bumper to install?
Re: Bumper search
[quote name='Copperhead' timestamp='1292807661' post='23799']
If you are handy ,should take you 2 to 3 hours ...just to let you know the ARBbumper comes in black....you will need to paint it if you want the look of the red one...need more info let me know tc@arbcanada.com we have them in stock front and back bumper cheers
Re: Bumper search
[quote name='T.C.' timestamp='1292864616' post='23814']
If you are handy ,should take you 2 to 3 hours ...just to let you know the ARBbumper comes in black....you will need to paint it if you want the look of the red one...need more info let me know tc@arbcanda.com we have them in stock front and back bumper cheers
Correction of email.....
tc@arbcanada.com
You'd think he could get the email address
Merry Christmas All! Drink lots and drive none. <img src='http://www.canadianhummerclub.com/forum ... tongue.gif' class='bbc_emoticon' alt=':P' /> <img src='http://www.canadianhummerclub.com/forum ... >/cool.gif' class='bbc_emoticon' alt='8)' />
