[quote name='Polar Bear' timestamp='1333536152' post='35885']
Hey Marc,
The rubbing will be normal...the toyos have large sidebiters and the yokos don't! Mine rub also...no biggie!
<img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
New shoes for the H
- Archngel
Re: New shoes for the H
- Bmszondi
Ya I get a little bit of rubbing as well. They perform great off-road as well went out last weekend and had some fun with them. Took everything I could throw at them, nice ledges, puddles, hills etc they did great. I'm running the right around 40lbs.
- Archngel
[quote name='Bmszondi' timestamp='1333550583' post='35894']
40 humm mine at 35 appears to be riding center, have another question too, did you have any problem getting them balanced, the tech here couldn't put regular clipped on weight on them because of the bead protector. they had to use the sticky ones inside the rims.
- yevych
Looks awesome Marc <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
2010 H3 Adventure 3.7L - Hummer evolution , 35" Mickey Thomson MTZ on 16" MT SideBiters, oem underbody & rocker protection, Safari snorkle, K&N filters, Air Doc intake, Rola roof rack, Off-road lights, Runva winch on High-Mount and Warn on tray, Outfitter heavy duty tie rods.
- H3Luxembourg
Hy Marc, i got 315/75R16 Coopers STT on mine H3,they are similary to the Toyos MT. Did lift the front 2,5" by torsion bars and at rear , lift shakels 1,5". Put Spacers at the front 1/4", result is you still have an verry verry little rubbing,so no problemo <img src='http://www.canadianhummerclub.com/forum ... >/grin.gif' class='bbc_emoticon' alt=';D' /> And if i don't wanna defenetly hear the rubbing , gonna put some 20mm spacers on front.
And with the lift, the tire combination and totaly underbody protection pac, i followed an freinds H1 everywere <img src='http://www.canadianhummerclub.com/forum ... tongue.gif' class='bbc_emoticon' alt=':P' />
mountains were created for Hummers
- Archngel
[quote name='H3Luxembourg' timestamp='1334755933' post='36248']
Im sure you could follow the H1 every where I've done it at Hummer school mouahahahah
Ill be at plaza on the 23 to get everything ready for summer fun, next mod, gobi stealth rack when I get back.
