Hey guys,
i was shopping for an upgraded sway bars for my 2008 H3 Alpha...only to find that my truck only has one. While the 2009 and up had two sway bars.. is it possible to install two sway bars like the 2009 model on my 2008 Alpha??
Second Question i wanted to install an ARB front air locker (my truck doesnt have one because its a 2008 model). awaiting your response guys....
H3 Alpha 2008 and 2009 & 2010
- AllenAventador
- Waldo
Re: H3 Alpha 2008 and 2009 & 2010
As far as the locker goes best bang for your buck would be to find a front diff from an '09-'10 with the electric locker. I had an air locker in one of my old trucks and even when installed an air dryer with my on board air system I had issues with the air line freezing the locker open or closed in the harsh Prairie winters that can hit 30,40,50 below 0.
As far as sway bars go, I don't really see why you would want to the limit suspension travel in these trucks if you go offroad and in my opinion, make the on road drive that little bit rougher. If you really want a set check out a GM dealer for OEM parts to swap in or GMPARTSDIRECT.COM then catalogue and look up the parts/price you need.
- AllenAventador
Thank you so much Waldo!! I actually wanted to upgrade my sway bar to the predator one or hellwig model just for giving the vehicle more control. I don't want to add one I just wanted to make sure it was possible. I will try to see if I can get an electric locker from an 09 or an 10 model alpha and install it. Thanks for the link
