One thing that I never liked in H3 was rear axle leafs mounting system... and the only solution that I knew was leafs over axle project that some people did. But it seemed too complicated.
Recently I found this awesome leaf spring plates: http://schwarttzy.com/product/h3-hummer-high-clearance-leaf-spring-bolt-plate/
Already ordered and will be installing before spring runs.
Just wanted to share with those who was annoyed with those low-hanging mount....
High Clearance Leaf Spring Bolt Plate
- yevych
Re: High Clearance Leaf Spring Bolt Plate
If you install would love pics, looks nice
- Toxicrider
Have a slightly different design high clearance plates on mine. Mine are solid plate machined with the proper bolt holes and shock mounts. Gives me 2" more clearance over stock.
These will help a lot! Normally the rear spring mounts are always hanging up the H3s! These will allow you to slide by without any issues!
- yevych
Screwed-up my first HD video and before/after pics... but made quick vid with instructions from whatever shots I had left... it's petty straight forward - just in case someone need a bit direction/help
https://www.youtube.com/watch?v=UXXgz2ZwAa8
Well, you made look easy !! Your truck is clean, 2" can be a big difference in certain conditions, very very nice
- yevych
Thank you Monk. It was indeed relatively easy install.
