how to remove drivers side door panel
canman
Post by canman »
hi everyone, well the door handle on my h3 is loose and the door panel needs to come off , I don't see any screws hiding anywhere that I have to take out. can anybody tell me how this panel comes off ? thanks . it is a 2006
Archngel
Re: how to remove drivers side door panel
Post by Archngel »
Hi Canman
There is 2 torx screws hidden under little flaps on the bottom of the arm rest and 1on the top upper part.
The door handle it self if i recall is screwed to the door panel.
The door panel is fixed to the door frame by white push in.
I suggest that you unscrew the 3 torx then start from the bottom unsnaping and work you way up slowly. Once all unsnapped lift the door panel to take it out of the rail at the windows.
Hope this help
Marc
canman
Post by canman »
thanks, I will give that a try
