Just finished my tire install, Have I gone too far?? <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Bigger is better
Bigger is better
- 03H2
Re: Bigger is better
i like it!!.. <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Have to get a little more flexible to get in. 30" to the door sill.Guess my wife will need a step stool made on a string to pull the stool into the truck. <img src='http://www.canadianhummerclub.com/forum ... unsure.gif' class='bbc_emoticon' alt=':unsure:' /> <img src='http://www.canadianhummerclub.com/forum ... /crazy.gif' class='bbc_emoticon' alt=':crazy:' />
- 03H2
LMAO <img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' />
- Hesh
Nice, what size lift and tire are you running?
[quote name='Hesh' timestamp='1323021476' post='33255']
Plow springs, 2" body, PitBull Rocker 41.5 * 13.5 * 16.5 on split rims with bead lock only.
These tires measure exact ,
not like Mtr's which 40's are 39
- Hesh
Yeesh, plow springs hey? How is the ride? How much lift do the plow springs give you on their own? Do you have any rubbing issues, or know of any yet? Looks savage, post more side profile side-by-sides, etc! <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
wow bro.....very cool <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
[quote name='Hesh' timestamp='1323024724' post='33258']
The plow springs are not bad to drive with.They make the truck sit up a little past stock height, And do not move too much. Good clearance all around except for the 4" tailpipe. I have to tuck it in closer to the inner wheel well or go back to the stock exhaust. <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
- Hesh
Can you post more pics? Like a side profile before and after shot hahaha? Also, like I asked before - any rubbing issues on lock to lock steering, or anything?
