Just found this picture,, anyone wants to try this on his H2,, Kevin?? hummm?? 49,,, i see you are tempted,,,
Mudder extreme
- Archngel
Mudder extreme
Hi guys
Re: Mudder extreme
Jeeexzzz what lift would that need?
44" on a Chevy truck was my biggest....
Our stock H2 with the front end torsion lifted was on 37's even that rub when I had full lock turn
- Archngel
Re: Mudder extreme
14 inches lift, apparently, im pretty sure it needed lots more mod.
Re: Mudder extreme
I have already run 39inch Michelin XML Military tires with no lift and only minor rubbing. And I have seen 42s on an H2 with only a 2-3inch body lift and I have also seen 46s on an H2 with 3 body lift and 6 inch suspension lift.
In the future I would love to stuff some 46s on my H2...but no Lift...just some "minor" body massaging to get those meats stuffed in there but with a front and rear Dynatrac Dana 60 IFS setup...yes front and rear!
Re: Mudder extreme
Dana 60s? Lol that's like dirty talk!! Hehe that would be insane, aaaand hold up I bet....I prefer that idea, with lower centre of gravity .....
Re: Mudder extreme
Wait! You Have No Idea Just How Amazing it will be!!Dana 60s? Lol that's like dirty talk!! Hehe that would be insane, aaaand hold up I bet....I prefer that idea, with lower centre of gravity .....
Btw, my current OEM axles are holding up just fine even when I ran the Super Heavy Michelin XML Tires!
I have beefed them both with 1541H axles front and rear so they can deal with shock loading!
