Finally getting some TLC
Injunfarian
CHC President
Re: Finally getting some TLC
Post by Injunfarian »
Yay! thanks for the update I love these posts. Looking good! Excited to be back behind the wheel... Getting tired of the Dodge Journey lol!
Cliff A
1998 AM General HMCO
Lambton Shores, ON.
www.eToolSmith.com
Slowing down till some parts arrive....plus getting a tad sore..OLD AGE  ::)
A rough parts list for the front end so far...
New lower control arms
Re used upper control arm with new bushings
Shim packed alignment buckets and shims--gets rid of the cam adjusted alignment which tends to move under a workout
New #70 shocks
New plow springs
New sway arm bushings
New tie rods--maybe have to check play and seized adjustment sleeve
New idler-maybe have to check play
New pitman-maybe have to check play
Rebuild steering box due to broken mounting bolts
New hub seals--input,output,ctis
Custom death wobble elimimater -- under reconstruction for resale --been tested in the worst off road areas on 2 trucks--Proven effective
Injunfarian
CHC President
Looking great! I am going to need to give it a good bath once she is home so the rest of her looks almost as good as the art your putting on her!
https://www.youtube.com/watch?v=1cmFWivQVTs
Cliff A
Lambton Shores, ON.
www.eToolSmith.com
Lol, now I'm glad roy is working on it.
Those videos!!
Wow, far from a street truck usage. :)
Impressive and fun looking
Injunfarian
CHC President
Yeah I use to abuse it alot, this go around will be different... I likely still will wheel it but only 1-2 events a year if that and even then I will be gentle with it, I use to wheel it pretty much every weekend. Thankfully now I have a few Suzuki's that I use for wheeling and my Hummer will be babied.
Cliff A
Lambton Shores, ON.
www.eToolSmith.com
Injunfarian
CHC President
Yeah I use to abuse it but all that is changing its going to be babied now.. and my Suzuki's are going to get the abuse.
Cliff A
Lambton Shores, ON.
www.eToolSmith.com
WIDELOAD
Post by WIDELOAD »
Following this rebuild...
Glad to see another Hummer on the road again.
James
1995 Hummer H1 Wagon
WIDELOAD
Post by WIDELOAD »
Looking good!
James
Well the front is almost done, started the rear disassembly today.   I think I should have taken the day off. Every major bolt seized on the right side....No blood but very sore. Grinders were out, bolt presses, and even the extended johnson bar.,
Finally got the right apart.  Another day for the left.....
