<p style="color:rgb(0,0,0);font-family:helvetica, arial, sans-serif;background-color:rgb(240,240,240);">Getting close to the end...
<p style="color:rgb(0,0,0);font-family:helvetica, arial, sans-serif;background-color:rgb(240,240,240);">gear hubs had spindles removed to replace seals and inspect bearings for pitting
<p style="color:rgb(0,0,0);font-family:helvetica, arial, sans-serif;background-color:rgb(240,240,240);">Replace as required...
<p style="color:rgb(0,0,0);font-family:helvetica, arial, sans-serif;background-color:rgb(240,240,240);">from my inventory
<p style="color:rgb(0,0,0);font-family:helvetica, arial, sans-serif;background-color:rgb(240,240,240);">Last bit of work under the body..
<p style="color:rgb(0,0,0);font-family:helvetica, arial, sans-serif;background-color:rgb(240,240,240);">Note.. if buying the 24 bolt military rims, the newer style does not have the slotted hole for the air line adapter so you will need to buy Cepek stainless lines
Finally getting some TLC
Re: Finally getting some TLC
- Injunfarian
- CHC President
Looks amazing! thanks for the update. I feel it is getting close!
Jesus, that's a big job.
Ita going to be sweet, lots of new stuff I see...
First time in 2 months she has her shoes back on.Outside for a quick rinse of pine needles and years of dust.
Alive but not running on Sunday night.
Monday...cough cough, started but ran out of fuel...
- Injunfarian
- CHC President
YAY, glad to hear you had her started even though it coughed a bit. I cannot wait to be back behind the wheel of it.
LOL, funny part is I think I like it Dusty gives it a mean look
- Injunfarian
- CHC President
It even had some moss on it... once I get it back hoping to give it a thorough cleaning and see what I can do about cleaning up that clear coat a bit to make it shine somewhat but it does have a lot of trail rash on both sides that will need to be addressed down the road.
Well she runs...and moves, Time to put the interior back together and get an e test.
Let the motor run for a bit , then replaced some worn out parts..Some of the belt had glued itself to the pulley
as well as the bearing being shot on the idler.
Not sure if I want to tackle the glow plugs.. playing this safe for now...8+ years without being re lubed..hmmmm
Getting very close now.
Next job is to tackle the stack to make sure there will be good cooling..lots of pine debris all over the rads.
Safety is ready, soon the e test
Out of curiosity how long did that truck sit before it was restored haha
Really nice to see the procedure of the rebuild
