Need the entire front differential assembly for my 2008 H3 - 5 cylinder.
Just lost the stock aluminum housing, 4.56 gears, wit no locker so need immediate replacement. Will consider Alpha cast iron housing or 4.56 with e-locker if price is reasonable. Also need gears if going with the cast iron housing, just to get things figure out before buying does anyone know a good source?
The sooner I can get one the better! New or used, no reasonable offer refused.
WANTED: H3 Front Differential
- JL
- Khamul
Re: WANTED: H3 Front Differential
I can't find anything online..... give Rick a call at E-Mortal and see if he has some ideas or Will as he's the parts guy!
Jl sorry to say this is dealer country most wrecks are bought here by dealers even before they hit the wrecking yards. As for replacement Can you wave waranty under dealers nose ( if you can't get it covered you may get a bill split on it. I take you destroied the case only if not check the Transfer case as usually Rhino destroies both at the same time ( 08 H3 Alpha). Also check in with TC as ARB lockers have replacement cases as well I Think.
[quote name='JL' timestamp='1297821371' post='25177']
See if this will work......
http://www.gmpartsdirect.com
GM PART # 15920599
CATEGORY: Differential Carrier
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $546.61
OUR PRICE: $317.80
http://www.allworldautomotive.com/featu ... 0524564371
Also....
http://www.sax-express.com/
read please..
http://www.hummerxclub.com/forum/viewto ... 82&start=0
http://www.hummerforums.com/forum/showt ... hp?t=19083
All up to you now...
GM PART # 15920599
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $546.61
OUR PRICE: $317.80
Also....
read please..
- Khamul
[quote name='Roy' timestamp='1297859254' post='25194']
GM PART # 15920599
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $546.61
OUR PRICE: $317.80
http://www.allworlda...id=330524564371
Also....
read please..
http://www.hummerxcl...&t=7182&start=0
http://www.hummerfor...ead.php?t=19083
U guys rock!!! <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
GM PART # 15920599
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $546.61
OUR PRICE: $317.80
Also....
read please..
- JL
Thanks for the links Roy! Much appreciated!
Just have to get it up past the border now.I think the ebay unit will cost less because the others may need every individual pieces ordered.Hope i am wrong to help your pocket book.
