Looking for a black driver side rocker panel protecter for A 2004 hummer H2
Thanks Steve
Rocker panel protecter
Re: Rocker panel protecter
Do you want the stock piece or an upgraded piece???
Either Way check with Roy he is your man!
Nothing in H2 inventory yet, Have tie rods, rear sway arm bushings--upgraded, front bushings for diff-upgraded
- citiboy
Where's your location?
Here's one.
http://www.kijiji.ca/v-carrosserie/laval-rive-nord/2007-hummer-h2-oem-rocker-guards/1036443668?enableSearchNavigationFlag=true
Here's one.
<div> </div>
<div> </div>
- Stevegt
Stock piece, thanks that would have been perfect but I'm located in Toronto
- madmayo
If your in TO. You should look up Stangs Fab. I believe he is Burlington. I have never used them but have seen their work. Lots of good reviews and happy jeep customers.
It would be nothing for home to make those. And they would last.
- Stevegt
Thanks, I'd like to see if I can find one first but I'll keep this in mind.
Still looking
Still looking
