Abs module, master cylinder, brake booster from abs truck
DerekCanuck
Post by DerekCanuck »
Hello, looking for brake parts to get an ABS fitted wagon ready for inspection, ive managed to locate the abs pump, now looking for abs computer, think its a wabco, wiring harness, and brake booster/master cylinder if anyone has access to a wrecked 99 and up?
Re: Abs module, master cylinder, brake booster from abs truck
see if you can remove all abs, computer is nuts for price,Have both master and hydro boost in stock for a 99.
Sold my abs computer for 1200$ used. Lists for 1700$ US---2100+$can
DerekCanuck
actually i did that with my 2000 as i want to go with lockers anyway, tt4 is of no use without abs if i understand the system correctly, but with the 2001 i need to pass an alberta inspection, i have the abs pump, and a few of the other odds and ends. if reasonably possibly to get it back to stock abs wise, i may move forward, yes abs parts are not cheap.. need to find a roll over donor....lol
DerekCanuck
hey Roy, for shits anmd giggles how far from your crank pulley to the front crossmember in your cummins swap? i would like to double check this one to compare the geometry. they did a really nice job of the engine mounts wondering if you have any photos of your front passenger body mount and how it interacts with your engine mount on that side.
zero clearance, modify front member . Used stock rubber mounts and made my mounts from there
DerekCanuck
ahh, this one is quite a ways back.
