As always, looking forward for another great event.
This is my last last year trip: http://www.youtube.com/watch?v=zNY3Gpa4oow
HUMMERS EVENT Mt. Tremblant in the Quebec
- yevych
Re: HUMMERS EVENT Mt. Tremblant in the Quebec
- Kapman
Ok question?????
At 7:35 in that video the H1 hits a rock with its front left tire that pushes it all the way to the left bump stop but the front right tire stays true??!?! WTF. What steering set up is he running? Did the drag link flex enough to allow this and just spring back??
- yevych
[quote="kapman"]
Ok question?
... Roy doesn't share his secrets :-) ... i saw his truck doing same thing few times on that trail... and he kept going...
Ok question?
Fully stretched suspension puts the tie rod at an angle,slightly worn idler, and a mildly worn UBJ. These all added up to extra tire swing.Normally the truck would have just gone straight over that pebble.
Now you all know the secret to the rubber tie rod.
Now, with added ground clearance this year,
I need to see:
how deep (was momentarily detained in 44" of Orillia swamp the second time thru)
how rocky (25"+ of body clearance),
I can put this frankenstein thru.
Anyone want to follow me into the bush???? Anyone?
I need to see:
Me, I can Follow you no Problem!!!
This will be weird though, you normally follow me on the trail and then you are the tow truck...but hey with my new Michelin XML tires I am ready to take on your ruts!!!
Btw, how come you have "added ground clearance this year" What did you do???? How come all these secrets?????
Deeper water pits, taller rock ledges,.... what can I say.
- Boeing Jet
I'll be there with the family so far. I'm just surprised that the hotels still let us in.
Guys info is up on my web site pdf files English & French
cheers
<a href="http://www.arbcanada.com/#!__events-eve ... enement</a>
see you all soon !!!!!
cheers
- Sub
nice, so hardcore day is when?
Registered and hotel booked!
Staying at the Residence Inn
