Wrenching Party
Here is a great place to Post events in your Area!!
GOTWAR
Re: Wrenching Party
Post by GOTWAR »
We will be there. I have lots to do
GreenMeanie
Re: Wrenching Party
Post by GreenMeanie »
If there is a shortage of things to do i have a drivers window regulator issue that needs a diagnostic. Motor works, switch works but window sticks halfway and you have to help it up or down past where it sticks. Hoping its a backed out screw or something simple.
Also need my starter looked at as it grinds out from time to time for like the past 5 years LOL
All other issues i have are too boring to get into for a wrenching party IMO
Always happy to help with other trucks as well. I think it would be fun to yank the Jagger motor. We could learn a bunch from that!!
Re: Wrenching Party
So far,
Kevin maybe a window alignment,H1
Ron maybe running boards on an H3
Chris has a project he is doing slowly H1
Sonny may need an e brake pull and brake check-- good truck to do a lot of teaching with
James may need a check over and some repair/tires
If all show, this could be a busy day of work and training.
Re: Wrenching Party
[quote="Toxicrider"]
Am available the 30th but the 20th I am wheeling up on Drummond Island in Michigan.
You should post these events for others to think about coming.
ROADBLOK
Re: Wrenching Party
Post by ROADBLOK »
[quote="Roy"]
Guess you've made up my mind for me.   :P
Re: Wrenching Party
I guess no body wanted to use the shop and tools,
I thank Chris ,Andrea, Kevin P. ,Ron and Kevin T. for showing up to lend a hand fixing trucks.
---nobody else showed---
They all did a great deed without getting dirty,other than eating at the BBQ.
On Sept 20., I will need a comfirmed showing or event will be cancelled.
Re: Wrenching Party
So nothing got fixed??? No mods or training??? :wtf:
eebh2
Re: Wrenching Party
Post by eebh2 »
I have my Fox 2.0 shocks on order for my H2 and should get them next week. Maybe I should cancel my install appt and bring them out to be put on. Also my rear wiper doesn't work just makes a clicking noise but the wiper does not turn. So I have work to be done. Also have a squeaking noise first thing in the morning when I turn right. Mechanic cannot figure out what it is as it only does it for the first 15 mins in the morning and then the sound disappears.
Re: Wrenching Party
[quote="Polar Bear"]
Nothing! :whatever:
Re: Wrenching Party
[quote="eebh2"]
Lets see whom else will be out, I do not like to shut down for a wrenching party and do nothing!
