HUMMER H1 FRONT SPRINGS REPLACEMENT
SELL Spare parts, OEM, After Market, what ever that is Hummer related and for your Trucks
Darcy
Post by Darcy »
I have a few different springs for sale
-I have a set of stock front springs for the h1 hummer used 1 month 500$ installed
- I also have a set of winch springs for the h1 hummer brand new 500$ installed
- for the offroader or someone who needs more clearance i also got a line on front firetruck springs rated at 3000lbs psi again 500$ installed
-GET THOSE SAGGY SPRINGS REPLACED not all hummers are prone to this issue but your truck should almost sit level
In some cases you will start scrubbing the hood itself and wearing out the fibreglass or rub the tub itself
not only does saggy springs screw up your handling it will cause premature wear on those nice 37 and up tires
heres a pic of a well overdue front spring change heres a pic with new springs
I have a couple styles available just though I would offer them to anyone local
take care
Heavy De
Re: HUMMER H1 FRONT SPRINGS REPLACEMENT
Great Deal Darcy...
srl
Post by srl »
[quote name='Heavyde' timestamp='1323911126' post='33563']
take care
Heavy De
What's the difference in coil with or with winch?
The load rating changes, a little more height as the springs do not compress as much.
Stock--750#
Winch--1250#
Plow --1750#
M1113 up-armoured--#2100 these really do not sag much.
They even lift the front end higher then the rear even with rear springs out of a 10800 rated truck.
The ride does not change much with the stiffness. Even the Beast with M1113 fronts does not ride any differently than stock, other than no sway from suspension.
And yes Martin, the truck is a bit higher than when she was at the rally. <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
thedub
Post by thedub »
[quote name='Roy' timestamp='1339523768' post='37840']
what did you do,,,,,, put freaking stilts on it <img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt=':huh:' />
[center]Yellow H2
Mississauga, Ontario.
(try that in your prius)
Hesh
Post by Hesh »
Ive heard the plow springs make for a very harsh ride.
[quote name='Hesh' timestamp='1339558833' post='37849']
Have not found any ride difference in the last 5 vehicles that have had plows put in them.Even with the M1113, ride is no difference, may be compensated with the 41.5 tires <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
